Currently reading:
Armeg Solid Board Cutter vs Super Rod Cavity Master
Discuss Armeg Solid Board Cutter vs Super Rod Cavity Master in the Electrical Tools and Products area at ElectriciansForums.net
h901
Hi everyone,
I need to purchase a solid board cutter and stuck deciding between the two. I prefer using a solid board cutter with the caps rather than using battens on the cut-out.
I remember reading somewhere that the Super Road version would cut very deep whereas the Armeg wouldn't go past a certain depth. Does anybody know if this is still the case or has Super Rod sorted it out?
Overall which one would you guys recommed and why.
Reply to Armeg Solid Board Cutter vs Super Rod Cavity Master in the Electrical Tools and Products area at ElectriciansForums.net
