Currently reading:
Auto switch not working on control panel for pump
Discuss Auto switch not working on control panel for pump in the UK Electrical Forum area at ElectriciansForums.net
matt2 bam
Hi having problem with my automatic sump control board the switch, for rain water pump, is not going onto auto mode when the water level reaches the float and the red light starts flashing and i have switch to manual I'm thinking the problem lies with the swich,marked K1 is there anyway i can check it out.
Do you have any photos of your setup? Sounds like float switch isn’t operating
When your float reaches its desired height then it should activate a switch which should supply power to your automatic side of your HOA switch. Good luck and welcome to the forum.
Reply to Auto switch not working on control panel for pump in the UK Electrical Forum area at ElectriciansForums.net
