Search the forum,
Discuss Baffled. Sewage eater. in the UK Electrical Forum area at ElectriciansForums.net
IMG_2319.jpgHi Guys. wondered if any of you guys have installed one of these or similar. It's a Marsh External compressor housing. Basically it for pumping sewage away and into an underground plastic cess- pool. Ground worker put everything in when doing drains etc.
SWA supply cable there and 2 x 16 amp skts. 2 x flexes. 1 flex for the air compressor and the other for the pump. No electrical drawings on site. I will try and search on the new later. There does not seem enough room to terminate a SWA cable. Thoughts appreciated
I had a similar set up a few months back,however,unlike yours,the pump was at the pit, the electrical gear was under a type of lid canopy
My swa was routed through the bell of the pit,looped back up through then strapped and terminated next door to the switchgear,my own adaptable box was used butted up to the switchgear
It ended up being secure after some playing around with fixings
Not too sure how to this. pump in pit + 1 flex for comp...looking at skts no room to get cables in
I would terminate the swa into an appropriate IP rated box then flex to each socket - on the assumption they are permanently powered by the sockets and are integrally controlled.... but worth checking with the manufacturers or the guys who dumped this crap on you (pardon the pun)
I have something very similar here at home. The compressor runs 24/7 and the pump has a float switch built-in to run when the water level is high so both are wired as permanently live from a single circuit.
As darkwood says, terminate the SWA into an IP box and then feed the two sockets - assuming the compressor and pump are wired to those sockets under the lid.
Where does the other end of the SWA go?
You can see the swa and two flexes. The flexes go into a commando plug each. The swa is obviously coming from the house/garage being the supply. Like darkwood says the swa should be terminated into an appropiate ip enclosure and then in two additional flexes come out of ip box to feed the commando sockets. If there is no room to terminate existing commando sockets you could always use trailing commando sockets or hardwire direct to the ip rated enclosure.
Reply to Baffled. Sewage eater. in the UK Electrical Forum area at ElectriciansForums.net
