Search the forum,
Discuss Bathroom Extractor Fan in the UK Electrical Forum area at ElectriciansForums.net
chris101
Just had the following extractor fan fitted for my bathroom, recommended by my electrician.
Based on the manual it states the fan should be triggered by the relative humidity % however since installation this morning, it has been continuously on.
I have spoken to the electrician whom advised it is made to stay on all the time.
Am I misreading/misunderstanding the manual?
I have set the humidity to 90% to test the threshold however it still stays on...
It's clearly possible to set up the fan in different modes, and what modes may depend on the exact model the electrician fitted.
By "Made to stay on all the time" the electrician hopefully means trickle ventilation is set to be on all the time.
An option seems to be to have trickle ventilation all the time (a choice of volume of air being moved), then a boost when humidity is detected (choice of 2 boost speeds), reverting to trickle at the end of the (selectable) boost period.
After explaining the various options, I would have hoped your electrician would set it up as you wished.
In many circumstances, having permanent trickle ventilation in the background is a good thing, and it's not regarded as energy wasting! However if the fan is running noisily, perhaps it's not that!
Reply to Bathroom Extractor Fan in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
Hi, my niece lives in a flat and has a bathroom without a window. There is an extractor fan which packed up and an electrician installed a new one...
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
Hi, Buying a replacement extractor fan. It falls into zone one with the room setup. Looking at two fans. One is rated zone 1 one is rated zone 2...
HI There, I would be grateful if you could help me, I have a very long duct between the bathroom and extractor outlet vent and for sometime, the...
