Search the forum,
Discuss Bizarre problem with PIR floodlight: how to diagnose in the UK Electrical Forum area at ElectriciansForums.net
HenryLaw
I have a baffling problem with a newly-installed PIR floodlight and I'd like advice from the forum as to whether it's defective (and should be replaced) or if I've done something wrong.
Background
My new house (2008) had six old-school halogen PIR-operated floodlights all round; only one of them actually worked, so I've replaced them with LED ones (10w LED Ultra Slim Sensor Floodlight - Warm White | LEDlite (LTUSF10MWWW) - https://www.tlc-direct.co.uk/Products/LTUSF10MWW.html). I had three of these in my old house and found them to be easy to install and effective in use.
The new units have a IR-connected control box about the size of a credit card. There are buttons to set the length of "on" time and the sensitivity; there are also buttons which change the "mode" of the light: permanently on; motion-detection all day; motion-detection at night; and off. There are also two other modes: "Flash", which makes the light flash on and off on about a 1Hz cycle; and "SOS" which makes it flash the morse letters S-O-S, rather slowly.
All the old units had a separate over-ride circuit on 3-core & earth cable, used thus: switch live black (sleeved brown); over-ride live brown; neutral grey (sleeved blue); and earth as usual. The new units have no over-ride cable; they are brown/blue/earth. So swapping old for new I've ignored the brown wire and used the other three as sleeved.
Most of the new units are 1:1 replacements for the old, but I needed one new light so have connected it with a run of 1.5mm^2 T&E connected in parallel with one of the others; connection is via an IP66 three-way junction box mounted well up under the eaves and largely out of the weather.
The problem
All but one of the lights, including the one in the new location connected in parallel to one of the others, work perfectly. But the other of the parallel pair (in one of the existing locations) exhibits bizarre behaviour: when set to "motion-detection at night" it sooner or later enters the "SOS" mode, and sits flashing until turned off via the control box. I have seen it spontaneously enter the "Flash" mode too, but SOS is more common.
Now the twist: I took the errant light off, put it on the bench in the garage and powered it up. It worked flawlessly. I left it overnight and every so often during the evening visited it: on it went, and off when the set duration was up.
Advice required
Is this unit duff? If so, why did it work on the bench?
If it's the way I've wired it, why does the other unit which is in parallel with it, and therefore wired identically, work perfectly? I had two in parallel in my old house too, for that matter.
If it's something to do with the exact location, what on earth can it be? There's nothing special about it - no sources of ionising radiation or whatever (!).
Good suggestions for diagnostic action, thank you both; when the rain stops I'll have a go. I'll start with disconnecting the parallel unit that does work, since it's slightly easier to do, and if that doesn't clear the problem I'll swap it for its twin and see what happens.
Poking wires into terminal block inside an IP66 box which is only just large enough is fiddly work!
Anyone nearby using a similar remote?
It is looking towards any place where folks might be using a TV remote or similar?
Otherwise as above, swap around and see if problem moves with the light or stays with the location.
My bafflement increases. I swapped the offending light with one elsewhere on the back of the house - one of those that's on a circuit of its own. I've walk-tested the back of the house three times today since dusk and everything works flawlessly! So, on the face of it, one particular unit in one particular place goes doolally; otherwise it's fine. It doesn't make sense.
But unless the fault develops more slowly than before, I'm sorted. Thanks to all for the advice and hope not to be posting back here with more ...
Reply to Bizarre problem with PIR floodlight: how to diagnose in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
Hi I have a 3phase shop in a high humidity area in (Hawaii) and I'm having some issues with low voltage on the single phase outlets on the 120v...
I have a box powering three 3-phase motors off of one 240V single phase line, NEMA 10-30. In the picture you can see a wiring diagram. The...
