Search the forum,
Discuss Blue Bosch Ignition Coil in the Auto Electrician Forum area at ElectriciansForums.net
The voltage provided to a car's ignition coil whilst cranking is less than the nominal battery voltage of 12 volts due to the high current drain to the starter. That may be as low as 8 volts so the ignition coil is rated at 8 volts. Once the engine fires, the terminal voltage rises back to the nominal 12 volts which is too much for the coil so a ballast resistor is switched in to reduce the coil voltage to its rated 8 volts. All well and good.
Bosch market an ignition coil called a "Blue Bosch" which has an internal ballast resistor.
Please help me to understand how that works - how is the ballast switched in/out? Is there some voltage sensitive device within the coil? Zener diode? A circuit diagram would assist.
Thanks.
Thanks.
Thanks.
Solved:
It transpires that it's nothing to do with starting, but to reduce the coil's inductive time constant.
Reply to Blue Bosch Ignition Coil in the Auto Electrician Forum area at ElectriciansForums.net
I have a 230 Volt single-phase circuit with a 100 Amp cutout fuse and a 100 Amp MCB switch, so the supply is rated at 23 kVA. Only about 13% of...
6K
I hear many views of people who believe that DPF's and CDPF's fitted to their vehicles are a problem and many people resort to removing them, or...
8K
Hi, I am new to the forum so firstly hello all. I have a basic understanding of auto electronics but have encountered a problem that is beyond me...
Hello all, I'm new here but have looked around first. I'm hoping for some help on a project I'm trying to create. I want to create a heated...
