Currently reading:
Bosch Dishwasher E15 code with bottom behind leaking
Discuss Bosch Dishwasher E15 code with bottom behind leaking in the Electrical Appliances Forum area at ElectriciansForums.net
Hi
I am looking at where does my dishwasher leaking. I find there is some leaking at the bottom behind but not from the hose pipe inside , since i failed to upload video here so i just screenshot some leaking photos, your advice on which part should be look at or replace is highly appreciated thanks
It could be a seal or the tub itself.
The e15 error is water in the bottom, setting off the float switch.
The bottom metal panel (in your first pic) comes off if you un-hook it. Maybe a screw somewhere.
I was wondering if you could see more when that is off.
The Bosch website spares section has exploded pics of all the parts, so you can see how it comes apart:
Keep taking bits off until you can see the problem. (But remember where they go and how they fit back!)
Or book a service engineer to attend to it, if you are not feeling confident about stripping it down.
Reply to Bosch Dishwasher E15 code with bottom behind leaking in the Electrical Appliances Forum area at ElectriciansForums.net
