Discuss brake lights are constantly lit when the key is on in the Auto Electrician Forum area at ElectriciansForums.net
mustang10
2010 Mustang - when the key is on, my brake lights are constantly lit regardless of whether the brake pedal is pushed or not. When the key is off the lights function properly - they only illuminate when the brake pedal is pushed! Any thoughts? I already replaced the brake pedal sensor.
Hey
How did you end up fixing the lights?
Would love to see a photo of the car!
Reply to brake lights are constantly lit when the key is on in the Auto Electrician Forum area at ElectriciansForums.net
I installed an illuminated switch (switch is lit when circuit is off) for my porch light. I noticed that even when off, my LED porch lite is...
Today I went to fix a minor loose screw on something and after switching off, etc, got out my Martindale VT12 continuity & voltage tester and...
I am trying to understand how a relay system works and have designed a circuit and a ladder diagram all as attached for an 8 PIN relay, a current...
Hi all, I have an issue with my brake lights coming on when I take the key out the ignition. Therefore running the battery down. The brake...
Hi all, I just found this forum last night and figured I would post my issue since I can't find much out there with a similar situation. My job...
