Discuss Burying Galvanised Steel Conduit in the UK Electrical Forum area at ElectriciansForums.net
I was wondering if any of you have any experience burying galvanised steel conduit?
My current plan is to make up the conduit, T-Wash it and give it a couple of coats of primer and hammerite before I sink it in the ground but I'm wondering if it will be enough? My Father has suggested covering it in heat shrink before it is buried? Is it needed?
The conduit will be the only CPC to an outbuilding so it's essential it cannot corrode over time.
And yes, I could run an SWA but I don't want to. :p
Sam
Sam
SWA would be my choice, why the reluctance to use it?
If you must use conduit, then I would pull in a separate CPC. I have come across several instances where conduits buried in concrete/ plaster have failed miserably in regards to acting as an earth, although they are 40/50 years old....install a separate earth conductor.
The conduit will be the only CPC to an outbuilding so it's essential it cannot corrode over time.Sam
What you are proposing to do is not acceptable.
If you are a spark you should know this, if you think you will be getting a spark to sign it off - they won't
Would you fit worn out tyres to a brand new car and race it around a track?
I once came across a 95mm 4 core SWA (installed 2007) where which was ran underground in a duct from a substation, ran downhill to a building. Where it was glanded into the section board was completely corroded as were the SWA armouring strands, could only presume the outer insulation was damaged during installing in the duct, and water has got in, and wicked its way out of the gland...luckily there was a separate earth cable installed!
New posts
Reply to Burying Galvanised Steel Conduit in the UK Electrical Forum area at ElectriciansForums.net
I’ve been asked to add a couple of extra points to the single ring main in a flat. Building fabric is concrete, all of the electrical installation...
4K
Hi, I have been asked to quote for a new café / deli and the owner is by trade a graphic designer. She is going for the industrial look. She wants...
Squid
Hey all, Excuse the ignorance here but I wonder if you lovely folk might have any opinions or better still be able to point in the right direction...
7K
M
Hi, I have been offered a rather nice Vectra estate (I know,sexy or what?) and was wondering if any one else owns such a magnificent beast. Does...
7K
miserly
M
A
Hiya all What we have is a holiday home site type effort where there are 13 caravan type looking units of accommodation. They do not have towing...
