Discuss Bussman NON-35 fuse fire? in the UK Electrical Forum area at ElectriciansForums.net
gashmore
Tenant reported that his fuse box caught fire. I found this stove circuit pullout. This unit was built in the 60s wired in aluminum but I found no corrosion and no indication of foil or other foreign material in the box.. The fuses are Bussman NON-35 Amp. Probably the original fuse from the 50s. I installed a new breaker box.
Never seen or heard of this. Any suggestion what happened?
Most likely cause is that high resistance had developed at one of the fuse end caps, which began to arc and burn material away until enough heat was being generated to scorch the phenolic moulding. There is a notch in the end cap that suggests it was the fuse element arcing to the end cap, although I suspect the initiating failure was more likely to be high resistance to the pull-out contact.
Reply to Bussman NON-35 fuse fire? in the UK Electrical Forum area at ElectriciansForums.net
Life is is clearly circular. A few months ago I can across in service a 1940s ish steel enclosed MEM "fuse box" and this week when doing a...
E
I think I've Posted this before, but I've just updated it. Some of the sparks where I work still get a little confused of what the different areas...
77K
Ok, so I'm registered with Rated People. I don't use them very often but once or twice I have purchased a lead that has turned out to be very...
