Search the forum,
Discuss Cable sizing earthing conductor in the UK Electrical Forum area at ElectriciansForums.net
Hi all,
Hope you're keeping well
I'm currently wiring a small commercial premises. 3 phas incoming supply, 16sq cables
As it is in an urban area with a busy pedestrian street on both sides of the building I had to drive the earth rod just inside the door of the premises. However it is located about 30m from the distribution board. Could anyone tell me how I would calculate whether I would need to run a 16sq earth cable or if 10sq would be sufficient. I'm conscious if a large fault current were to flow and 10sq being adequate.
Building is also neutralised. Which brings me to my next question. If a premises is neutralised, why the need for an earth rod.
Appreciate any advice here. Thanks
Reply to Cable sizing earthing conductor in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Merry Christmas to everyone, and apologies for talking work during the holidays😅 I have my first EV charger install job early in the New...
Afternoon all I am looking for some advice as on what to with the suppliers earth after a conversion to a TT system. Current issue is earthing...
Hello all, I wonder if I can get some opinion on my deliberations on an old TPN installation with numerous 1P sub-boards wired up with 16mm T&E...
Hello All I was pondering an idea recently regarding the ground connection to my property. At present it has a combined Neutral to earth at the...
