Discuss Can I add PIV to lighting circuit with no RCD protection? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Phil C
As I've mainly done site work and moved into domestic recently, I'm a bit rusty on stuff like this, but if I'm adding a loft PIV unit to an existing lighting circuit via an unswitched fused spur, if the lighting circuit has no RCD protection am I allowed to install it?
Same question for if installing a new socket to a ring, or an extractor fan etc.
No to all. Also would require a means of isolation for PIV - pulling a fuse wouldn't be acceptable.
I don't mean to seem disrespectful, but this isn't the sort of issue to be rusty on.
Reply to Can I add PIV to lighting circuit with no RCD protection? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi Customer has an extractor fan that’s inside the shower cubicle high up on the wall. The extractor fan has no form of isolation and is wired...
Hi I have a job where customer has two families one families lives upstairs and one family will live downstairs. As the property is going through...
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
Hi, I've just had some electrical work completed in the bathroom; I've recently refurbished the bathroom, replacing the old electric shower with...
8K
I'm doing a college design project and need to choose a suitable range of circuit protective devices for the whole contact. I've chosen and...
4K
