Search the forum,
Discuss Can you join 2 thin wires with a thicker one? in the Auto Electrician Forum area at ElectriciansForums.net
MrPinger
Howdy, I was wiring in a couple LED lights for my trunk bar and diffuser but ran into a maybe problem. The trunk bars wire wasn't long enough for where I wanted it to go and what I purchased after turned out to be a larger gauge. Can I use a thicker wire as a link between 2 thinner ones?
Reply to Can you join 2 thin wires with a thicker one? in the Auto Electrician Forum area at ElectriciansForums.net
hi looking to install a new induction hob to current wiring . the wiring i have is thick white probably about 15mm wide and is hard wired into...
Hi all. I'm trying to put a light-bar on my (facelifted) Land Rover Freelander 2. I'm wanting to wire it so the light-bar will be energised when I...
Howdy DIY soldiers, first post here. My question comes down to whether it would be particularly unsafe for me to temporarily wire nut and tape a...
Before I pay an electrician to come check my work, I thought it worth a post here. I don't want to pay the cost of a small car for a whole-house...
