Currently reading:
Can't get overload circuit in house working again
Discuss Can't get overload circuit in house working again in the DIY Electrical Advice area at ElectriciansForums.net
tim1977
A circuit in my house quit working when a toaster oven and portable electric heater where both running on it. Normally the simple fix would be resetting the tripped breaker. However, the breaker did not appear to be tripped. I turned it off and on just to make sure and still no luck. Next step I unplugged everything that was plugged into receptacles on the circuit. Nothing still. Next step, I replaced the receptacle that the toaster and heater were plugged into when the circuit went out. Northing still and no sign of damage to the receptacle I replaced. Next step, I replaced the circuit breaker. Nothing still. The really odd thing is one of the light fixtures on this circuit put off a slight amount of light when the switch is turned on. So slight you can only tell it is giving off if there is very little other light in the room. You can turn this on and off both by flipping the normal switch in the house you would use for that light as well as turning the breaker on and off for the entire circuit. I'm out of ideas for troubleshooting this problem. Any ideas?
Given your DIY status it really is at a stage where you need to call in a professional, it may be the case your wiring is damaged, I would recommend you leave the circuit off for safety reasons until you can get it inspected and tested.
Just for a response to your query, there are several possibilities here with some of them been a fire risk or electric safety risk to yourselfs, as we do not know whether the circuit is even wired correctly or the breaker sized correctly we cannot make a call on the issue.
You put - 'normally the simple fix is resetting the tripped breaker', are you saying this as a observation of a fault in general or because you have done this several times with this breaker in the past?
Reply to Can't get overload circuit in house working again in the DIY Electrical Advice area at ElectriciansForums.net
