Discuss Car battery to Power inverter set up in the DIY Electrical Advice area at ElectriciansForums.net
chippy818
So I'm looking to connect my car's battery directly to a Pure Sine Wave 2000w power inverter So I can use it on job sites etc to power a microwave of above 1700 watts.
My question would be, Do I need to have a one-way fuse in my wire setup directly from the battery to the inverter? Or can it be safe to assume that the power inverter would have its own fuse for this purpose?
In addition, should I be connecting a ground wire directly to soil or would it be safe enough to connect to a conduit object that has any form of earth contact?
Thanks in advice.
  • Optimistic
Reactions: DPG
Don’t bother, 3 to 5 min of microwaving will take a car battery from full to empty.
even if you can start your van afterwards, the duty cycle will write off the battery within a month.
Reply to Car battery to Power inverter set up in the DIY Electrical Advice area at ElectriciansForums.net
Hello, So I purchased a Novopal 2000w/4000w(Peak) Pure Sine Wave Inverter DC 12V to 110V/120V. I purchased this so I can hook it up directly to...
I used 12v dc from a 13 plate car battery to power a 12v dianamo dc motor and brought in an alternator to change the battery using the rotation of...
M
The idea of having electrical power from 240volt AC sockets in a sectional building not on the national grid is becoming popular among those who...
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
Hi everyone. The owner of the business I work for along with myself have created a DIY inverter setup that is giving us some issues. We bought...
