Discuss CCTV cameras outside in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
trying to work out a route is always better ,has for using cat 5I also thought about using a flat Cat5 cable and just run it through the window.
What would you do
I would say if you can possibly put in PoE cabling you will have a far more reliable system (subject to backup power for the PoE switch of course, but probably that would apply to any wireless system's router & recorder as well).Anyone used wireless cameras as CCTV, obviously battery powered, but how long does the battery last, or can you get sola powered ones.
Reply to CCTV cameras outside in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
