Search the forum,
Discuss Change bt master phone socket for metal face plate in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
Hi all,
Trying to change a facetted. Not sure how to do it. Got a bit master phone line with this layout
A White
B Orange
2 White
3 Green
4 Black
5 Orange
I want to change it for a new metal face plate, which has
1 2 3 4 5 6
What do the cables do.
Thanks for your help
Cheers Tony
OP, just an extra thought, if you have an external master socket, which looks like this...
https://community.bt.com/t5/image/serverpage/image-id/4457i566829BEBBCD442F/image-size/medium?v=mpbl-1&px=-1
Then you can do whatever you want with the sockets inside your home.
I have a master socket like in the picture in the garage
OK, just open the front cover of that. You will be able to see which colour wires are in 2 and 5 in there.
(If 3 is also connected, make a note of it also.)
At the indoor socket, take the wires out of A and B and use the colour code found in the garage to connect to 2 and 5 (and possibly 3)on you new socket. Then whatever wires were on you old socket in 2, 3 and 5, just punch those wires into the same slots on the new socket. You will have two wires in the same IDC slot, this is normal.
You'll need a krone tool by the way.
Wasn't aware of these,
Yeah, they were invented for new housing estates, to save BT/OpenReach having to enter all the properties, faffing with huge bundles of keys and wasting time.
but it appears they're discontinued now.
Then along came FTTC, which they're not compatible with, so if you order BT fibre, they have to remove it and swap it for a standard external BT junction box, like a BT66b.
Reply to Change bt master phone socket for metal face plate in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
DIYer here. I'd like to install an electric car wall charger myself. It calls for 6/2 romex which I have. Unfortunately my panel is in my...
Following the tragic tale from @telectrix about lightning damage to phones and modem leading to a serious loss of beer money I decided to take a...
Ive managed to fluff up my bt incoming cable and from what i can find out there are two wires, one orange and one white that should go to...
Something simple, I think.... my understanding is that the BT master socket extension is unfiltered. Does this mean that I can run it to a RJ11...
Hi guys, first time posting, please bare with me! I have an old test chart as shown in the pics that i would like to get running. Everything...
