Search the forum,
Discuss Checking proper bonding and grounding for office trailer w/generator power in the DIY Electrical Advice area at ElectriciansForums.net
WesCV04
Hey guys and gals.
We bought a small office trailer that is wired up. It's never seen mains power and uses a generator disconnect (220). I read up on the myriad of code situations for bonding and then grounding, neutral switching etc. and came to the conclusion this would fall under separately derived system. So I verified the main panel and all interior wiring was unbonded with my meter and made sure the generator itself was neutral bonded. Following that I attached the only ground to the ground lug on the generator approx. 30 feet away to a ground rod I sunk.
Does any of that sound correct? I'm a little unsure what's meant by first point of disconnect, is that the switch or the generator itself? It's a standard cord and plug unit using a L14-30p.
Edit: I also changed out the 50 amp main breaker for a 30 amp, since it's a 30 amp unit.
Reply to Checking proper bonding and grounding for office trailer w/generator power in the DIY Electrical Advice area at ElectriciansForums.net
Legends, need some advice. I am a 12v automotive electrician, but have had a side project building a concession trailer for my dad. We have an...
Before I pay an electrician to come check my work, I thought it worth a post here. I don't want to pay the cost of a small car for a whole-house...
I have a Generac GP8000e generator that I plan on back feeding the main panel of my home with the portable generator, power inlet box L14-30a and...
Hello, I live in Mexico, where I have a small, un-official trailer park on my property. The property is serviced by my privately owned, 650amp...
I have an existing EmerGen Switch installed in my main panel that links to 10 breakers. The main panel is located in the basement. I recently...
