Discuss Connect Led fixture 2 wires, to ceiling light with 4 wires. in the DIY Electrical Advice area at ElectriciansForums.net
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match the wires to the led light fixture. The 2nd light has 2 red and 2 black. Because the 2 lights are wired together. How do I put a led light fixture on this light? How do I wire the fixture to the 4 wires on the 2nd light. The led fixture only has 2 wires. 1 red. 1 black
Reply to Connect Led fixture 2 wires, to ceiling light with 4 wires. in the DIY Electrical Advice area at ElectriciansForums.net
Replacing a light fixture in an older home. The ceiling box has two cables, each with a hot and a neutral (photo attached). The old fixture had...
I am adding a light fixture in a room I am restoring in my 160 yo house. I have ran a new 12-2 w/ground wire from the ceiling box to a junction...
Hello, my house was built in the 1950s and every time I look behind a wall plate the wiring isn’t how it’s shown in any DIY book I’ve read. I’m...
Hello everyone, hope all are well. I'm changing a ceiling rose and have lost the diagram showing where everything was connected (to the old light)...
Hi we are replacing light fittings in our home. Im confident with the fitting aspect, but have run into doubt in making the right choice of...
