Search the forum,
Discuss Connecting Extractor Fan in the DIY Electrical Advice area at ElectriciansForums.net
Hi
I connected black wire to neutral and red one to Live one, but extractor fan still does not work. Please see photos attached.
Does it mean I need to split red wire into 2 and connect to the very left and very right sides to make it work, or am I missing something?
would appreciate an advice.
yours kindly,
Igor
The fan appears to be a timer version, which requires both L and SW L to be powered for it to operate.
Just fit an link between the two.
And sleeve the bare earth that is waving about.
Thank you for your reply! much appreciated!
if it is okay, may I ask how do I fit a link between the two? Or where could look up how to do this?
Just never did this before,
Yours kindly,
Igor
You just need a short length of red with both ends stripped. Maybe 3cm long
Bend it over to make a “U” shape.
One end goes in with the red you’ve got, the other end goes in the far right empty terminal.
Ideally, the left is for a permanent live, the right is for the switched live from the light. Fan would come on with the light, then timer would keep it running for a while after the light was turned off. But that would need another cable.
Before anyone says anything, this appears to be a replacement (paint marks on wall) so we can assume it’s in a sensible place, and wired correctly.
Reactions: DPG
Reply to Connecting Extractor Fan in the DIY Electrical Advice area at ElectriciansForums.net
I’m replacing an old 100mm extractor fan in the kitchen with a new one. The old one was a pull cord fan whereas I bought a timer one (no pull...
Hi all, I'm in the UK and have recently had a ducted extractor fan Mixflo 200W with timer fitted. The fan comes on with the pull cord and runs for...
I've installed a replacement bathroom extractor fan. Pic on the left is the old one. Pic on right is the new one. Wired the same way but the fan...
Hello, I'm swapping my extractor fan in the UK and I have bought a Turkish extractor fan stupidly and the connections you can see in the picture...
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
