Discuss Connection advice please in the DIY Electrical Advice area at ElectriciansForums.net
banksy
I'm replacing a fluroescent tube with an LED strip light.
Photo shows the wires which connected to the old tube light (single one way switch).
The new LED light has a short pre wired cable with live and neutral wires only.
How do I connect the new LED light to the old wiring, retaining the same switch?
You either need to fit a suitable box or ceiling rose to those cables.
The blue with the brown sleeve to live, the other blue to neutral.
Leave the two browns as they are just connected with each other, the earths need a connector fitting to them.
Reply to Connection advice please in the DIY Electrical Advice area at ElectriciansForums.net
Replacing a light fixture in an older home. The ceiling box has two cables, each with a hot and a neutral (photo attached). The old fixture had...
Hi, I am restoring an old art deco, wall mount medicine cabinet. The cabinet has an 18” fluorescent light tube on each side. Before I put a lot...
Hey all, I'm not sure if I'm over thinking this, but I can't seem to find the answer to what I believe should be a simple question. I picked up...
Hi, I need some advice on the wiring for a new ceiling light. I have taken down the original light, and I'm left with the wiring in the image...
