Discuss Converting 12v suspended tension wire to LED? I in the UK Electrical Forum area at ElectriciansForums.net
I have an old IKEA Norrsken 12v suspended ceiling tension wire system, which runs x7 20w MR16 bulbs, from a Min 4x20w/Max 10x20w transformer.
Can I replace the 240v/12v transformer with an LED driver, alongside 7 new LED MR16 bulbs, say, 5w each, or is the plastic coated cable not suitable for LEDs?
If yes, do I need to ‘overspec’ the driver, given the cable length (3-4 metres) or just go for a straight 50w driver?
Yes you can fit a constant voltage LED driver in place of the transformer.
LED lamps may work with the existing transformer but from my experience it will shorten the life of the LEDs and they may start to flicker after a period of time.
Reply to Converting 12v suspended tension wire to LED? I in the UK Electrical Forum area at ElectriciansForums.net
I purchased a house that has a really cool 12v halogen setup where two wires are suspended across the ceiling in two different locations, and each...
Hope this is the correct forum for this. I have a chandelier that holds 18 bulbs, it's not in use since ages ago and I was planning to restore...
Hi all, I converting a van to a camper and wanted lights for underneath the kitchen cabinet. I purchased this led light strip for Home Depot...
I have garden LED light running fine through a transformer.. LED Driver Adapter AC 220 -240V To DC 12V Transformer But am now trying to add a...
6K
Hi all, first post so be gentle... I've recently decided to replace the MR16 50W Halogen bulbs in the bathroom with 5W LED ones. I'm aware of the...
