H
harmonica
I have a light fitting with 2 x 70w T8 tubes in it. The ballast is a regular tridonic ballast for these lamps like this one Tridonic T8 Pro High Frequency Ballast 2 x 70w.
How do I convert this fitting into an emergency fitting? Would I be able to do this with the above ballast and wire in a battery pack or would I need to change my ballast also so that the battery pack will work? Thanks
