Search the forum,
Discuss Could someone explain to me what the numbers on bulbs and batteries mean? in the UK Electrical Forum area at ElectriciansForums.net
joshboe
Hello,
Apologies if these are really basic questions, I know next to nothing about electronics and such. I'm quite an outsider here.
I'm looking to build myself a moth trap, and I've found that (especially in today's economy) actinic bulbs running off a battery would be best as it would be cheaper in the long run running it off the mains or using a mercury vapour bulb running off a battery connected to an inverter or a generator.
Anyways, I've found a suitable actinic bulb, the Sylvania 0025706 BL368, which is 20W and 230-240V. Firstly when it says 230-240V, is this how much power is needed to turn it on?
I've been trying to research appropriate batteries and came across a battery size calculator, and inputting the 20W and 240V I got a load size of 0.1A and 2Ah. Does this sound about right? I've been looking at batteries and a lot of them seem to be 12V, and in my mind that seems far too small.
Thank you for reading, and any help would greatly appreciated.
-Josh
The Sylvania 0025706 is a mains AC voltage lamp, and would need an inverter to run off a battery (which provides a DC voltage).
First, please explain the significance of the battery. The following comment is ambiguous and confusing:
Did you mean ...'cheaper in the long run THAN running...'?
Running anything off a battery is always more expensive that running direct from the mains.
If this is meant to be portable, then how long do you need it to run on a single charge of the battery? Just to give you an idea, a car battery would power a 20W lamp for about 30 hours via an inverter.
We can look at more specific numbers once it's clearer what you want to achieve.
Reply to Could someone explain to me what the numbers on bulbs and batteries mean? in the UK Electrical Forum area at ElectriciansForums.net
J
The LED light is for a moth trap (identifying not killing). At the moment I'm using 8 AA batteries. The batteries are 2000 mah so 1.6 amp hour...
B
Prefix - I've tried to post this in automotive, but it would not let me. This may be because I have not been recently active. Apologies if this is...
E
First of all, I would like to apologize for creating an account solely to ask my question. I honestly don't know where else to turn to find out...
4K
Afternoon all, I'm new here and this is my first post. I recently posted on another forum with a rather long post about a problem in my...
4K
DonaldJ
