- Reaction score
- 1
Im looking for some advice on some dc wiring i have in place. Currently i have some monitoring equipment that wont run when connected to a run of wire about 40m long (1.5mm diameter) it is connected to a 12v 100ah battery and what i think is happening is the voltage drop over that distance is preventing it from running.
The device powers on but the pump wont run and kicks in a power failure error (draws about 6A current to start pump). I have tried the model down in equipment and it works fine (draws about 5A current to start pump)
Im just wondering how much to scale up wire diameter when i rewire it or if this is even the most likely issue?
I was planning on putting in 4mm wire but concerned this may be overkill
