Search for tools and product advice,
Discuss Dewalt or Milwaukee tools in the UK Electrical Forum area at ElectriciansForums.net
Dewalt for me, about 6 months now. So far so good.
Was using Milwaukee before that working with another fella, they are good too, but heavy due to the steel casing, though if you're clumsy or likely to have others use your stuff they would be a bit more tolerable for abuse I'd imagine.
Dewalt had a few extra items I thought better, so that was another reason too.
Im a dewalt man myself but know a few lads that have Milwaukee and they can't rave enough about them but I'm only domestic so not like I'm going to be using heavy work loads all the time
Always used dewalt never any bother, but could never get the jigsaw blades to stay in the chuck, had both jigsaw slide and stick pack same problem. Originaly went for dewalt 14 v because of metal chuck when others were plastic , stuck with them ever since. Most of the top brands are comparable.
The 2 brands were virtually side by side in test results. I watched a load of video tests lol plus they have both 3 year warranty. I think the Dewalt is slightly less cost than the Milwaukee.
My advice would be to go and see what's available in both the ranges, and price them up to see which best fits your budget. Either in a tool store or online, and don't be afraid to ask your local guy to price match online,
Mine beat the cheapest online place I could find.
Went for Milwaukee several years ago, have had no fails yet. The 18V sds gets used and abused every working day, highly recommended. Their brushless stuff is as powerful as you will ever need. Batteries are cheap too and don't have a programmed maximum number of charges like Makita batteries do. They make a lot of specialist tools as well.
My sds is a Bosch, most of my other gear is Dewalt. I was getting fed-up with lack of power when drilling joists using either. After some investigation I also purchased a Milwaukee 18Volt Fuel combi, and it has twice the power of the Dewalt. I can't recommend the Milwaukee enough.
I'm also a big Milwaukee fan, all my gear is Milwaukee.
and, to topit all, there's no yellow on milkwalkies
got me one of these still going strong !
I have a range of milwaukee tools - if retooling I'd reconsider and look into Bosch blue and DeWalt range.
Failures I've had;
- Mains/battery relay in jobsite radio
- Trigger switch in circular saw
- Clutch in brushed drill
- Electrics in brushless impact driver (common issue), causing switch issues
- Milwaukee branded battery failure after warranty period, 3 of 4 orig batteries failed.
Initially i bought Milwaukee as at the stage here in Australia, they hadn't 'taken off' and I didn't want the same gear as everyone else and the builders I worked with, they'd have used or knocked off my batteries... Now most ppl I work with have Milwaukee and by far in my opinion it's muc better than Makita gear which my boss uses, when I use it - it's underpowered and cheap feeling...
Batteries I've sourced from ebay have been half the price or less and hit/miss, when I get good cells (LG or Samsung) I've found the aftermarket batteries better than the supplied ones, they've lasted longer and in a couple of cases were actually manufactured in a better way in my opinion.
Looking forward, battery replacement price is an important issue, warranty coverage and claims (the ease of), for me I've had a choice of repairers and they've always done a good job, quickly, and not asked questions.
Try the tools out, feel them, try and actually use them in terms of driving some screws, drilling some holes etc then go from there is my suggestion! Good luck!
I have a Makita sds 18volt which I've never had a problem with and highly recommend. I also have a Milwaukee 12v fuel Impact drill which is one of the best and useful tools I've ever purchased but i must say i did have a problem with the trigger not functioning correctly which i sent off and drill was repaired and sent back to me within 7 days, might just have been a one off as a lot of other people highly recommend Milwaukee. That issue hasn't put me off though and i think eventually ill purchase some of there 18 volt products.
Can't remember if it was Dewault,Milwaukee, or Makita, or maybe "Rawlplug". Strange thing was, the batteries either went flat very quickly or could last some time , depending who was using it. Must of been a connection problem with them. Lol
Reply to Dewalt or Milwaukee tools in the UK Electrical Forum area at ElectriciansForums.net
I was working alongside the plumber yesterday. I had to drill some 32mm holes through joists. I always use my Makita 481 high torque drill will a...
Hi all, I have a first fix on a new build to do in a couple of weeks or so and I am looking to buy a cable stapler. Standard stuff: Twin and...
This week at Electrical2Go we have a selection of NightSearcher products that are over 50% off! We even have a selection of NightSearcher Kanga...
Good evening all, I'm thinking to buy a Dewalt impact wrench for containment installation, sometimes can use for car tyre changing. Which size...
As I have retired now (really!) I have decided to sell my electrical tools etc. They include hand tools, hilmor galv. conduit bender 20/32 with...
