Discuss DIY: 20A oven installation on 40A circuit, can this be done? in the DIY Electrical Advice area at ElectriciansForums.net
titan2023
Here is my situation
  • We have a dedicated oven circuit in our house with a 40A RCBO
  • We have bought a dual fuel range cooker which states it has a nominal power of 4800W
  • By my calculations this means it will draw max 20A
  • The power cord of the oven is rated to 25A
My question:
Are we permitted to connect this directly to the 40A circuit, or should we get the 40A RCBO replaced with a lower rated RCBO (e.g. 25A)?
Edit:
I believe it is allowable, because the oven are a fixed load?
Reply to DIY: 20A oven installation on 40A circuit, can this be done? in the DIY Electrical Advice area at ElectriciansForums.net
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
Howdy experts, I normally run 6mm T+E for cooker circuits, housing authority spec. I'm changing my gas inbuilt double oven and hob for...
Hi, we are replacing our old hob and cooker and I need a bit of help, to make sure all is safe. This is the oven and hob specs: AEG IKB64401FB...
Hello, new here! Would greatly appreciate some input. I'll first say I intend to get an Indesit technician to take a proper look tomorrow, but...
Hi, The current state of play is a standalone combined oven and hob supplied by single cooker circuit with 40A RCBO, 6mm cable, isolated by cooker...
