Currently reading:
DIY Campervan conversion
Discuss DIY Campervan conversion in the DIY Electrical Advice area at ElectriciansForums.net
Hi all,
Apologies if I am not posting in the correct place I am new to using forums - I'm looking for some advise on my campervan conversion electrics.
1. The attached diagram is what I am intending to wire up (for a basic set up for lights, charging phone and a powered coolbox). I am just looking for someone who can check it and tell me if I have made any huge/potentially dangerous mistakes?
2. I have installed an AGM battery which I am told requires venting in faulted conditions, I have a small campervan so I am worried about the potential hydrogen off-gassing. The battery came with a plastic vent tube which I could attach and pass through a drilled hole in the vehicle floor. Would this work/be safe?
Thank you for reading my post, any advise you can give would be much appreciated.
Harry.
Reply to DIY Campervan conversion in the DIY Electrical Advice area at ElectriciansForums.net
