Discuss DIY Question - Is this SWA? or Hi-Tuff in the UK Electrical Forum area at ElectriciansForums.net
My sister has a cable feeding an outside boiler (see image). I want to tidy it up by adding a new piece of cable as shown. I can't see any ends of the existing cable to determine whether it's SWA or Hi-tuff. Is there any way of determing whether this cable is swa?
doesnt look big enough to be SWA or hituff....
Can we get a close up photograph of the cable showing a couple of those clips?
Actually.... if it used to be clipped all the way, then it might be long enough as it is...
Check for any written details on the outer sheath.
If you want to replace it you'll have to trace to remove it.
As above, can it not be re routed?
Thanks for getting back to me. The cable certainly feels like swa or hi tuff. The cable goes into the loft and is black there - it's been painted white outside. It presumably goes back to the wiring centre fot the central heating but I'm not going in there!! It's not clipped at all outside. I've measured it and it's not long enought to be neatened to a vertical drop. I can access the loft - will the cable be marked to identify it in any way? Is there a detector that would pick up the steel?
ah ok... so the clipped cable is going to the light fitting there?
I would think SWA is thicker overall diameter for the same size and and number of cores than hituff... Any way of measuring?
Will it just be a L,N,E feed cable, or possibly a multicore carrying signals from thermostats etc?
edit: Can you see how the cable terminated into the boiler there? You don't need to take any covers off, just see if there's a gland.
SWA will have a shroud with a brass gland below. Hituff will just likely be a normal compression gland.
It should be 4c.
SL-L-N-E
Sometimes 5c if the valves are jammed into the boiler.
There might be an unpainted section of the cable after it enters the boiler.
You should be able to see it if you take the door off the boiler, there is a turnkey handle at the base of it.
Also to add the bend radius on the bit coming out of the wall is not looking too good, it should be around 8 * diameter and that is rarely sharper than a 5" drain pipe.
In that type of house the cable is sometimes fed from the attic following the roofline as the walls can be problematic to get through.
Sometimes >2ft thick stone with the middle being rubble filled.
Path of least resistance.😆
Reply to DIY Question - Is this SWA? or Hi-Tuff in the UK Electrical Forum area at ElectriciansForums.net
Just wanted to know which people use. My case. Client converting attached garage into new rooms. Consumer Unit has to move to accomodate this...
Hi guys, Can I ask you a DIY question? I'm refurbing a detached garage and adding a garden building. Garage currently has a submain supplied by...
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
Hi all, I am planning to install wall lights such as these ones (LAP Bronx Outdoor Up & Down Wall Light Black - Screwfix -...
