Discuss DiY: Where can i get hold of a 13a 20mm ceramic fuse in the DIY Electrical Advice area at ElectriciansForums.net
robins
For Vax pressure washer. Internal fuse is blown but can only fine 10a and 15a online. Any recommendations appreciated
Thanks but sadly they do not have 13A versions. Would it be OK to use a 12A or a 15A version?
Reply to DiY: Where can i get hold of a 13a 20mm ceramic fuse in the DIY Electrical Advice area at ElectriciansForums.net
DIY'er question: I have a singe switched fused spur above my kitchen counter, providing power to an undercounter fridge socket beneath it. The...
Hi All. What is the best/preferred method when connecting 20mm conduit to a back box of a socket on an outside wall ? I am connecting a BG...
Hi, I have a project I have been working on, that has me out of my depth with regard to my knowledge, as I am a very basic electronic hobbies...
  • Locked
I read once, never seen one for sale, that there is a solid brass replacement for the standard 13A fuse in a 13A plug. This is to eliminate the...
12K
Hi all, First post here, hope I'm compliant with the rules! I did do a quick search before asking this, but I couldn't quite come up with the...
