- Reaction score
- 8,188
"134.1.1 - ....etc. The installation of electrical equipment shall take account of the manufacturers instructions"
It's on a 32A breaker
Discuss Domestic remodel - Sanity check on a couple of things in the UK Electrical Forum area at ElectriciansForums.net
Because most people (except electricians) have no idea of safe zones I tend to try and limit the use to the most obvious locations where possible. Since the zone description is 150mm from the angle of two adjacent walls I do not think that this applies for a penetration through a wall such as a window frame.There is a 150mm safety zone created at the angles of two faces of the wall no? Therefore it is within a safety zone where the window is, but that zone stops 150mm below the window sill... at least that's my take on it.
Must admit, I'd never thought of a window opening as usable as a safe zone. Would you also regard a door opening in the same way?There is a 150mm safety zone created at the angles of two faces of the wall no? Therefore it is within a safety zone where the window is, but that zone stops 150mm below the window sill... at least that's my take on it.
Think the whole zone thing is a daft idea, only sparks know about it.
I certainly agree with the above,it would not be so daft if the zone secret wasn't limited to the very people who install the cables and also the knowledge expanded,not only to include other trades, but rammed down the throats of the designers of kitchens,these seem to have no perception of the absolute chaos their efforts can cause
Reply to Domestic remodel - Sanity check on a couple of things in the UK Electrical Forum area at ElectriciansForums.net
