Search the forum,
Discuss Dual Metered Distribution Board in the Electrical Tools and Products area at ElectriciansForums.net
mattg4321
Been asked to quote for a job where the small power and lighting needs separate metering.
I’ve not come across this before as I usually only do small commercial, which I believe is exempt from this requirement. Anyone know the actual requirements as per regulations? Anyway I digress.
I assume I’ll need a dual metered dis board. Such as Hager JKD188TM. Also require SPD at this dis board. I’m aware this will be extra, but before I sit on hold with Hager, does anyone know if this board comes complete with 2x meters?
Can anyone recommend something similar, that is possibly better. I’m sure Schneider will do something really nice, but perhaps more money. All comments welcome.
Schneider Merlin Acti9 Isobar P 8 + 8 Way 125A TP+N Type B Split Metered Metalclad Distribution Board​
They do one.
Nice, but £3k! However, Hager not much less.
Don't know Schneider that well for SPD kits, the Hager kit that goes along side the main switch is well engineered, though think it is 125A or 160A max supply protection for it as no separate MCB.
The Hager SPD kit in a 4-way TPN board, with DIN box below:
Reply to Dual Metered Distribution Board in the Electrical Tools and Products area at ElectriciansForums.net
As a retired electrician, I need to specify a new type B board for a village church. Principal load is heating. Ipfc phase to phase is 1.1kA...
Has anyone fitted an SPD to a schneider standalone AFDD DB. Isobar P B Standalone Active distribution board, Acti9, 24 AFDD ways This board only...
I have a fuseboard change I need to do soon I’m putting in a FUSEBOX 7 or 10 way RCBO+ SPD My only concern is how I should run the pyro cables in...
I know I’ve seen them before…. But I can’t think of a name. I’m needing a line of metal back boxes in a kitchen… 2 lots of 2x 2 gang and a 1...
Need help with a quote here. I’m wanting some sound advice. Was called out to the hot water not working so repaired the issue within the panel...
