- Reaction score
- 17,094
He wants to bond copper pipe that may or may not be joined together with plastic fittings?
Discuss Earth bonding to Water in the UK Electrical Forum area at ElectriciansForums.net
I am looking to confirm if bonding is required to the copper pipes even when main supply is via blue plastic pipe, I feel the electrician who I met may just be making up some work to earn money !Out of interest only, why did you suddenly decide you needed to know if bonding was required to the plastic piping? just intrigued
He wants to join the copper pipe regardless that the main supply is via plastic pipe, he says metal pipe inside property needs to be bonded regardlessHe wants to bond copper pipe that may or may not be joined together with plastic fittings?
Yes, it may be just following the rule of thumb, but I was wondering if its really required, I don't see a nearby earth only connection that is coming from earth block, however I do see there is nearby socket with earth connection, I think the earth from the socket shouldn't be used for bonding ?It is common practice to bond copper pipe installs even though the supply is plastic , not a requirement but often worth running the cable as plans may change etc or there may be a cable there from a previous install and hey ho if its there just smash a clamp on anyway. Newer installs with plastic supply and only isolated sections of copper with most runs in plastic are another matter and you just wouldn't consider they needed a bond . Doubt the guy is trying to stiff you probably just being a bit 'rule of thumb' about it.
the electrician quoted £150 to do the EICR test and minor fixes as it will take around 4-5 hours,
however he finished the test in less than 1 hour (he checked CU, some sockets and switches) and now asking me to pay 150
, he also quoted 200 plus material to fix the errors including earth bonding to water pipes.
I do not feel good and while I respect all professionals, I feel I am being ripped off !
i agreed to pay 150 for 4-5 hours work, but he did some tests for less than 1 hour, he is expecting me to first pay 150 and then asking for another 200 to do fix some errors.If you received a quote for £150 and agreed to proceed based on that quote then yes of course he is asking for £150 because that is the agreed price.
If you feel the work has not been completed to your satisfaction then you need to discuss that with him and get it resolved before paying the bill, but it won't change the price.
1 hour seems very fast for doing an EICR but without actually seeing the installation we couldn't comment definitively.
Have you had any other quotes for the remedial work to compare it to?
Reply to Earth bonding to Water in the UK Electrical Forum area at ElectriciansForums.net
