Currently reading:
Economy 9 Meter / Consumer Unit
Discuss Economy 9 Meter / Consumer Unit in the UK Electrical Forum area at ElectriciansForums.net
Calza2k
Hi all,
Last month I moved into a flat that is on an economy 9 tariff and meter (it has wet heating). In this scenario, I have one consumer unit which seems to have both elements inside.
I'm experiencing issues where the off-peak isn't being used as it should be, and while I continue to battle on with EDF's complex meter team - they don't really have a clue either. (My heating circuit isn't getting its mid-day boost, and my power circuit isn't going off peak in the early hours. However my heating IS going offpeak in the early hours).
I've attached a photo of my meter and the consumer unit if it provides any clarity, but my main question is - what determines when to use the peak / off peak circuit? Does something in the consumer unit tell it when to switch?
photo upload website
The meter does the switching. Either internal time clock or radio teleswitch.
The only circuits that benefit from off peak tariff are the 2 on the right in your consumer unit.
Gone are the days when all your electric was charged on the less rate overnight.
I’m not sure whether every supplier has the same tariff patterns. EDF might not have an “E9”, but have their own “off peak” set up.
Brilliant thanks - seems like the meter is faulty then. I'll push harder with EDF to get it replaced, as the heating isn't going off peak in all the hours that they say. They have specifically told me my E9 tariff is off peak at:
Heating
10pm - 12pm
2am 5am
5.30am - 7.30am
1.30pm - 3.30pm
Power
23:30 - 06:30
But from what you have said, it looks like none of the sockets are ever going to be off peak?
Are you sure of this? I've no experience of E10, never heard of E9, but plenty of E7, and on all of these ALL electricity to the house in the off peak 7 hour period is charged at the reduced rate. The meter shows either rate 1 when electricity is charged at the higher price and the switched output from the meter is off, or rate 2 when all electricity is charged at the lower rate, and the switched meter output is on.
I'd say it's worth having a decent sparks have a look at that. (And sadly it seems that finding sparks that understand heating and off-peak is getting harder)
To me your photo carries all the hall marks of a consumer unit that's been monkeyed around with by someone who is not 100% sure what they are doing.
There are wrong-brand RCBO's.
There is a B50 RCBO worryingly labelled boiler.
There is a B32 RCBO worryingly labelled cylinder.
There is a B50 MCB on the right that is a different vintage of MK and not original, and may not be the correct device.
Do you have any time-clock controls for heating / hot water?
How many immersion elements are there in the hot water cylinder, one or two?
Oh that's a worry! There was a new hot water tank and boiler installed earlier this year, the rest I would think is original to the build in ~2001.
The heating and hot water are controlled by a "regular" electronic control - where I can customise start and finish times per day for each of them, boost etc..
I'm not sure RE immersion elements, I was advised to keep the immersion off and use the (electric) boiler unless an issue arises. The two cables going into the control panel on the tank are pretty small though, like the sort you'd get on a normal domestic appliance (unlike the rather chunky one going to the boiler). There may be another cable going in round the back, but there's no space to see.
Electric boiler - I missed that, sorry. I'm not as concerned about the B50 size now.
That also explains why they fitted an RCBO.
While technically there are wrong-brand components used, most of my concerns have gone with that information.
This is from SSE​
What is Smart Economy 9?​
Smart Economy 9 is a tariff with two rates for people with electric heating and a smart meter.
It’ll give you peak and off-peak rates for your electricity at specified times throughout the day.
Take advantage of nine hours of cheaper, off-peak electricity as it’s not just your hot water and heating that will be charged at the cheaper rate.
We’d advise trying to use more energy during the cheaper times where you can. Your nine hours are split across the day into three 3-hour blocks, so it should be easier to make the most of the cheaper rate.
Your cheaper, off-peak hours are the same if you have a Pay As You Go (prepayment) meter or a credit meter. They might vary by up to 10 minutes, but here’s a rough guide:
Off-peak times in GMT​
  • 3am - 6am
  • 12pm-3pm
  • 7.30pm-10.30pm
Off-peak times in BST​
  • 4am - 7am
  • 1pm - 4pm
  • 8.30pm - 11.30pm
Your smart meter’s In-Home Display will show the rate you’re being charged.
I was going by the history up here when Scottish power brought out Total Control heating tariff to supersede their E7
Had a 3 section CU. Part general power and lighting…. Part 24hour panel heaters, and part off peak through the time switch.
Each section has its own rate.
Not necessarily so, I get cheap rate between midnight and 6, one set of tails, one meter
It gets a bit more interesting. It seems like the off peak labelled section of the fuse box has no neutral and nothing connected to either fuse:
With my limited knowledge, all I can guess now is everything is connected to the "heating" circuit?
(and I still need to query with EDF the times the meter thinks it should be honouring that as off peak, rather than peak).
So if the boiler is capable of drawing peak and off peak rates, it must mean the entire circuit (including sockets) are already on "heating" circuit right?
And the "power circuit" is basically not in use here.
Sorry I don't know what you mean but looking at the picture everything to the right of where it says cylinder has nothing connected to it so your power for everything is coming from the big red switch at the left hand end and presumably on one rate
EDF say I have two circuits. A "heating" circuit and a "power" circuit.
Both are capable of going peak and off peak, but at differing times.
From this, it looks like everything is on the same circuit, EDF would have no way of knowing what was drawing power..
Not a very safe setup. A four core SWA cable is used: Yellow-earth red-live peak blue-live off peak black-neutral for both peak and off peak. If there were circuits on the off peak side and someone switched off the peak main switch, everything would appear dead but the off peak circuits and the neutrals on the peak circuits would all be live during off peak times. A 3 pole main switch should have been installed to switch both lives and neutral, or the incoming neutral split with a suitable connection block and then connected to both main switches.
The whole setup is a mess and it appears the heating system peak and off peak wiring is incorrectly configured. I'd highly recommend hiring the services of an electrician who understands electric heating systems to check it through carefully and install it properly.
Is there any way to tell what circuit everything is being fed by?
Both are active permanently, they just switch rates depending on (differing) times of day. I'm never up late enough to run experiments in the early hours!
Also, as the black neutral is xonly connected to the left hand and not the right, is it even possible to use the off peak in its current state?
Reply to Economy 9 Meter / Consumer Unit in the UK Electrical Forum area at ElectriciansForums.net
