Discuss EIC (Electrical Installation Certificate): editable PDF based on IET Model form in the Electrician Resources and Downloads area at ElectriciansForums.net
happysteve
Supporter
happysteve submitted a new resource:
EIC (Electrical Installation Certificate): editable PDF based on IET Model form - Looks just like the IET model form... but you can edit, save and print it in any PDF viewer.
This is an EIC (Electrical Installation Certificate), complete with Schedule of Inspections and General Schedule of Test Results, in the format of a PDF. You can fill out the details using any PDF reader. It is derived from, and pretty much identical to, the IET model forms, at: http://electrical.------.org/wiring-regulations/forms/2015-amd3-forms.cfm?type=pdf The only thing I have added is a "Ref" field in the top right of each page, for you to add a reference (e.g. invoice...
Read more about this resource...
I found that I could not save any data into this PDF or print it with any of the data in it. Just in case anyone else has the same problem, I downloaded acrobat reader. I then opened the PDF in acrobat reader and this allows you save and print whatever you write in the PDF.
Can you insert your own company logo?
Use Adobe Acrobat Reader (the free version). If you've got the posh (expensive) version, I think you can just add images anyway... Anyway, on the free version:
Click on the "signature" icon (looks like a fountain pen)
Click "add initials"
Select "image"
Find your logo on your hard drive
Now, as well as signing the form with your signature (which should be your actual signature), you can also sign it with your "initials" (which is your logo). After you add your signature or your logo, the form will no longer be editable (after you've saved it), so make sure this is the last thing you do.
Unfortunately, Adobe Acrobat converts the image to black and white. But it's better than nothing :)
Hi, I've downloaded this and am using acrobat, I've partially filled it in but it will not let me save it to fill the rest in later. When I click on save or save as, the save box comes up but nothing in it, any help gratefully received
Reply to EIC (Electrical Installation Certificate): editable PDF based on IET Model form in the Electrician Resources and Downloads area at ElectriciansForums.net
happysteve submitted a new resource: EIC - Electrical Installation Certificate - BS7671 2018 + A2:2022 - Fillable EIC PDF form for 18th Edition...
happysteve submitted a new resource: MEIWC - Minor Electrical Installation Works Certificate - BS7671 2018 + A2:2022 - Fillable MEIWC PDF form...
Eh up :) I've done some new PDF forms for BS7671 18th Edition Amendment 2 2022 (the Big Brown Book), based on the IET model forms. You can fill...
12K
happysteve submitted a new resource: Circuit details + test results - extra sheets for EIC/EICR - BS7671 2018 + A2:2022 - Fillable circuit...
happysteve submitted a new resource: EICR - Electrical Installation Condition Report - BS7671 2018 + A2:2022 - Fillable EICR PDF form for 18th...
