Search the forum,
Discuss EICR needed in Reading in the UK Electrical Forum area at ElectriciansForums.net
I need an EICR done on a house I rent out in Reading, England - 4-bed detached built in early 1980s. Would ideally like someone from this forum.
Last EICR was in March 2019 following which esteemed forum member Wilko put in a new DB, did various fault finding, earth upgrades and everything else to clear the faults. But 5 years is up and I know he has retired.
Reply to EICR needed in Reading in the UK Electrical Forum area at ElectriciansForums.net
Hi, I need an EICR done on a house I rent out in Reading, 4-bed detached built in early 1980s. But I'm a bit nervous about how to avoid cowboys...
4K
I've recently has an EICR (report attached) carried out on my two bed flat because I need to rent it out for a year. The electrician has come back...
I commissioned an EICR to be done on a property that is in Wales as this is now a requirement in order to let on any new tenancies after 1st...
What certification do I need when replacing a consumer unit ? Here are the details. I am semi retired (electrician) and work for a company as...
8K
Evening all. I did an EICR recently and then changed a consumer unit. As part of the EICR process I take off around 25% of all accessories to...
