Search for tools and product advice,
Discuss Electric boiler better than a heat pump? in the Need help with ElectriciansForums.net? area at ElectriciansForums.net
Reply to Electric boiler better than a heat pump? in the Need help with ElectriciansForums.net? area at ElectriciansForums.net
Hi all, I've noticed that my UFH pump is not always turning on as soon as the stat & valve calls for heat. This results in hot water passing...
My customer wants to be able to switch his heat pump (3.5kW) for his swimming pool on and off remotely, he also wants to be able to set times for...
https://www.theguardian.com/technology/ng-interactive/2023/dec/23/heat-pumps-science-visualised?CMP=Share_AndroidApp_Other This guardian article...
Up until now I have steered clear of heating systems. I now have quite a bit of work with a builder and will be expected to deal with the...
Hi all, taken on a new build project and they have quite a large property with three separate manifolds. I have wired before with one manifold but...
