Search the forum,
Discuss Electric heater blows up but circuit still works for fan. in the UK Electrical Forum area at ElectriciansForums.net
jloaks
My Lasko electric heater stopped working and I thought it just played out so I replaced it with another heater that worked fine for a while, but when I went back to check it was also not working. A fan is on the same circuit and has been that way for years, the fan still works fine. Is this maybe a grounding problem or a bad breaker? I don't want to try another heater for fear it might blow up too. How can I check to see if it is safe for a new heater?
I guess you are saying that all the smoke come out of it or did it actually blow up. I’m baffled right now but the only thing I can think of is that you have a neutral problem somewhere. I’ve read on my meter before 180vac with a neutral problem in the panel. You need to hire an electrician and he can check on what the voltage is for each breaker
Reply to Electric heater blows up but circuit still works for fan. in the UK Electrical Forum area at ElectriciansForums.net
In a property with two consumer units one for the ring main etc., and the other for the 1970s storage heaters (storage heater CU looks like it’s...
Hi, I replaced an outdoor electrical socket recently with a 2 gang, BG socket which has LED lights to show when it is switched on. Since then I...
Hello and good evening I have been asked to take a look at a Sunhouse sshe125 storage heater. The heater’s fan is not working and Dimplex have...
