Discuss Electrical Layout diagrams in the Electricians' Talk area at ElectriciansForums.net
Afternoon,
I need to create an electrical layout plan for a factory with around 30 DB’s.
What software would be best to use, I have AutoCAD electrical but that seems more for electrical control panels etc.
Currently I’m using AutoCAD and just drawing all the DB’s, but is there any free software?
Thanks.
With AutoCAD you could get a DWG of the plan of the factory and then import that to your drawing and add your equipment. Then everything is to scale.
Why do you want to use some other software?
Below is a link for a search of "Drawing" in the title.
Hello Chris,
There is a free software toolkit for electrical designers – MeteorSpec. It’s a CAD-plugin. Supported CAD platforms are AutoCAD® BricsCAD® and GstarCAD. You can find MeteorSpec on MeteorSpec LT - CAD software for analysis and designing low-voltage distribution networks - https://meteorspec.com/
The toolkit consists of the following components:
- MeteorSpec-NETWORK – software for simulation, analysis and calculation of 0.4kV distribution networks;
- MeteorSpec-ELECTRIC – collection of various calculators for electrical designers and students;
- MeteorSpec-PLINE – totally customizable multipurpose tool for summarizing lengths and areas of any objects that can be modeled by lightweight polylines.
Afternoon,
Thanks.
it depends on. I´d usually use autocad 2D for one line diagrams and transformers, and some Revit for core busbars and busways.
It all depends on what you want. I spent years doing circuit & simple layout drawings using AutoCAD LT. I don't have that luxury now, so I use NanoCAD 5.0, which is similar enough to an early version of LT.
NanoCAD 5 uses the AutoCAD 10 (IIRC) DWG format as well as DXF.
It's quite easy to design your own blocks for any symbols you need. If you keep them in a special drawing you can copy and paste them into your working drawing.
Reply to Electrical Layout diagrams in the Electricians' Talk area at ElectriciansForums.net
Help please! Got this to use as a doorbell but unsure of specifics and wiring. If someone could maybe help with a diagram/specific parts or even...
I'm after advice on how best and safely to do a friends Fuseboard upgrade. Current setup is a Wylex 6 Way board with MCBs of 2x 6A, 2x 32A and 30A...
Hi, I recently moved into a house with electric storage heaters and am looking to replace them with electric radiators. Gas and oil are not viable...
Hello everyone. I bought some property in northern Michigan. It has underground electric with a transformer already on the property. I would like...
Does anyone know of a free electrical drawing program that I can use to draw neat circuits consisting of a mains supply (fuse board) mains sockets...
