Search the forum,
Discuss Electrical service ampacity in the UK Electrical Forum area at ElectriciansForums.net
I need to calculate the service ampacity of a building. The wire is 250MCM (copper). 3 wires coming in. These wires provides power to 6 - 60amp panels.
Anyone can help me to determine the service ampacity? What i know is the 250mcm wire can hold up to 290amps.
With the information given there is no way to help you.
Where I live 250 MCM is derated for the temperature. So it becomes 200 amp wire.
Some POCO's keep track of the demand and KWH provided to a meter. Some do not.
Load calculation is a start to answer your question.
Reply to Electrical service ampacity in the UK Electrical Forum area at ElectriciansForums.net
  • Locked
My house was built in the 1930s, The fuse in my service cut out is 60Amp and the wire coming from the street has a 16mm2 copper core(easy to see...
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
Ok, can somebody please explain, with exact code reference and steps/reasons why this works. MCA 37amps. MoP 60 amps. Why can I land #8 on a...
Hi there, I was wondering if anyone could advise me on the WT Henley Series 8 house service cutout. I have one of these installed at my house and...
I'm starting a new construction single-family residence, I know with the 2020 NEC they require an emergency disconnect on the exterior of the...
