Electrical2Go - Megger MFT Deals!
Upgrade your toolkit with our exclusive offer! Purchase any of the Megger advanced multifunction testers – MFT1711, MFT1721, MFT1741, or MFT1741+ – and receive a complimentary MFL205 Fuse Finder. That's not all! When you choose the MFT-X1, you'll also receive the 1013-316 Fuse Test Leads at no extra cost, as well as the MFL205 Fuse Locator AND a 12 month licence for CertSuite! Don't miss out on this fantastic deal to enhance your electrical testing capabilities. Available for September 2023 only.
The Megger MFT1700 series, presents a range of multifunction testers that excel in diverse electrical installation scenarios. Uniquely designed to be ingress rated to IP54 (ensuring dust and rainproof protection) and CAT IV rated (a rarity in multifunction testers), these devices are engineered to thrive even in challenging environments.
MFT1711: The Megger MFT1711 is a versatile multifunction tester designed for various electrical installations. It offers a 200mA continuity test, insulation resistance testing at 250V and 500V, RCD testing, a two-wire anti-trip loop test, and more. With its IP54 and CAT IV ratings, it's suitable for domestic and commercial applications.
MFT1721: The Megger MFT1721 is a step up from the MFT1711, offering additional capabilities. It features a 200mA continuity test, insulation resistance testing at 250V, 500V, and 1000V, RCD testing, a two-wire anti-trip loop test, and more. Its enhanced features make it suitable for both domestic and commercial installations.
MFT1741: The Megger MFT1741 is a high-performance multifunction tester tailored for a wide range of electrical installations, from domestic to industrial. It provides a 200mA continuity test, insulation resistance testing at 250V, 500V, and 1000V, RCD testing, two-wire anti-trip loop testing, earth resistance testing, leakage current measurement, and more. With its advanced features, including an IP54 rating and CAT IV rating, it's an ideal choice for comprehensive testing.
These multifunction testers from the Megger MFT1700 series are designed to cater to various types of electrical installations. They offer a combination of continuity testing, insulation resistance testing, RCD testing, loop testing, and more. Depending on your specific needs and the complexity of the installation, you can choose the model that best suits your requirements.
Shop MFT1700 Series
The MFT-X1 is Megger's innovative addition to their established MFT1700 series of multifunction testers. This cutting-edge, platform-based, upgradeable tester introduces a range of new features developed through years of customer feedback. The MFT-X1 includes True Loop™, Megger's industry-leading loop impedance test, which comes equipped with patented Confidence Meter™ technology. Additionally, the tester is fully compatible with CertSuite™, streamlining the certificate generation process.
This multifunction tester also offers high-resolution loop testing, stabilised insulation voltage output, a vivid full-colour display, and an easy-to-use new interface. Its user-upgradeable software ensures adaptability to future regulatory changes, making it a go-to instrument for fast, accurate, and versatile testing.
Designed for a wide variety of low-voltage electrical installations, including EV charging points and domestic solar panel systems, the MFT-X1 is perfect for both initial commissioning and periodic maintenance, as well as in-depth fault diagnostics.
Shop MFT-X1 Series
Electrical2Go - Megger MFT Deals!- Continue reading... over on Electrical2Go Blog New and Offers
This has been posted on the Electrician Forum | Electrical Advice forum.
Discover the Megger MFT1700 Series: Unmatched Performance for Your Electrical Installations
Shop MFT1700 Series
Designed for the electrical testing of single and 3-phase installations
Shop MFT-X1 Series
