Search for tools and product advice,
Discuss Electronic Lock using 74LS74 DTFF in the UK Electrical Forum area at ElectriciansForums.net
_q12x_
Im making this cct for fun. Ive seen it in a video on youtube, with different IC's. So I decided to adapt the cct to what IC's I already have.
And it is working perfectly, both in simulator and in reality (on breadboard). But while building it, testing it, and playing with it, I noticed a problem.
If button S53, the one with C4 in parallel to it, is pressed, it will bounce a bit, and the CLK on pin 3 will activate -multiple- times. Most of the time, the contact is as it should, only once and the CLK will be activated normally. But in random times, the button will bounce, depends the way Im pressing the button I guess. The cct behave like this: doesn't matter how many times any other button will bounce, it will still create the logic flow, correctly, even if Im purposely press, for testing reasons. But this last CLK button, S53, is tricky in the logic chain. If pressed once, it will activate the Unlocked LED, and the AND gate will set to LOW, the first 3 CLK's. But if pressed once more, the second time, it will toggle the LED off, but also the AND gate, and in turn, it will reset the entire logic flow to it's start.
My question to you is this:
- How to make S53 be pressed only once, and on other presses, doesnt matter if bounced or intentionally by my finger, to not clock anything anymore. The only real reset will be S54. So far, I can reset from 2 buttons, S53 and S54. But S53 should not reset the cct, only S54.
This is more as a fun challenge.
My immediate solution is to use another FF (Flip-Flop) only for this S53 button. But... Im afraid I might complicate things way too much.
Im very curious what you will come with.
Thank you.
(click the image to enlarge and zoom in)
https://www.jameco.com/Jameco/workshop/TechTip/555-timer-tutorial.html
Have a look at figure 6 in the link above. I reckon you ought to be able to work out a way to use this 555 monostable circuit to do the work of S53 to clock the final flip flop. And the 555 RESET input set LOW to inhibit further action in response to the pressing of S53 until the 555 RESET goes HIGH - (what S2 does in figure 6).
You can use the logic Q or Q* outputs of the final FF U2B and/or U3 to set the 555 RESET input LOW or HIGH depending on the state of the final FF U2B.
The resistors and capacitors connected to S1 of figure 6 debounce the contacts.
I picked a 555 circuit because I know you have some in stock.
Have fun working it out.
Thank you mister @marconi
I solved the problem actually, yesterday. I also thought on using a 555 as well. We are on the same line of thought, which is very GOOD !
I did it with a discrete Flip-Flop cct. Also with a discrete AND or Binary Bit cct.
Also with a 4081 AND gate IC.
It works perfectly in the simulator ! It remains to test it on the breadboard.
It was HARD to do it, but Im proud I did it.
Thanks for being on the same line of thought with me ;)
Nice to see discrete transistors used to make circuits. I don't know if you do it but I used to and still do take a dc voltmeter with the negative inout connected to the 0V rail and then use the positive probe to measure voltages at various points of the circuit in order to imprint in one's mind and later on confirm all is well. eg, when a silicon transistor is turned on there ought to be between 0.6 and 0.7 V between its base and emitter. Similarly measure collector to emitter and base to collector.
  • Im not very proud to say that Im not measuring mostly anything when Im making my circuits. I know I should be more ... disciplined in this direction. I am though, using hints from placing LEDs in various important locations of the cct. Usually a LED will signal me most of the time, if something is wrong, either in the entire cct or in a module. It is somewhat equivalent to measuring with a voltmeter (as you describe it). My way is more...visual. Heh. It works this way with microcontrollers and why not, with normal ccts.
  • The only exception Im turning to measuring, is when I hit a wall, when I can no more intuitively distinguish the problem(s). So in extreme cases, Im starting to measure, as you just said/explained. But not as a normal day-by-day thing.
  • Im also checking a transistor, as you already explained, but only when I dont know exactly its E-B-C pin order, or when Im unsure if its working or not, damaged. Its an alternative to using the transitor tester. I do use this 'manual' mode from time to time, but not as routinely as I did it before having the tester.
  • I hope it makes sense. If I didnt understood your point, then clarify further.
- And thanks for your answers. Also to our silent viewer, mister DPG. Haha.
To be very sincere, Im not very sure I understand to what are you referring in your advice.
Hahaha,
No, seriously, you should not believe -everything- is written on internet as the facto. Hahahaha.
I don't. I like to think for myself. You are aware that every language, every country and its people has its different and regional ways of thinking things. Right? The same goes to words and expressions. We romanians, or at least here in Moldova territory side of Romania (not the Moldova country) , we are quite literal in our speaking and reading language. English is using a LOT of shortcuts for weird phonetical sounds or letters or symbols. For me, "a thing or two" literally means "a thing or two", which is very little. And not "a lot" - hahaha. Be careful what you choose on internet. I am.
THis guy here that is explaining the meaning in this article, he is using sarcasm in its explanations, or simply ill will just to f*uck people minds, to give some obscure new sense to the expression. It's my VERY strong impression. I do not think is a normal explanation, even if im not a fluent or consistent english speaker ! It's my impression. Very funny though. Haha. You little... ;)
I always enjoy your threads q12x. I admire the way you stick at things until they are solved.
And the differences in language and culture are fascinating. The world would be a boring place if we were all the same.
Here is what a top UK university says the meaning(s) of 'a thing or two' is/are and they would not use sarcasm just as UK Collins, a reputable dictionary, did not either in the the previous link:
a thing or two - https://dictionary.cambridge.org/dictionary/english/thing-or-two
I would use 'a thing or two' in my speech and writing and I tend not to be sarcastic which is oft called the lowest form of wit.
In your #3, is the note about C7 actually referring to C6? I can see why C6 may be required in a simulation of the circuit to reduce the frequency response of the circuit to avoid high frequency oscillation and also to progressively reduce the impact of high frequency thermal noise of one of the 'state switching' transistors. But I do not see such a low value having much impact using real components where like for like they are not electrically identical as they are when modelled in the simulator.
If you ponder for a moment this - there actually needs to be a minute difference in electrical response between the two halves of the bistable circuit otherwise it would settle happily on a 'knife edge' ie: for exact similarity between both halves of the bistable circuit the transistors would be partially on to the same degree. Real components inevitably provide the minute difference between the two halves.
As a further learning point, one sometimes see capacitors in parallel with R79 and R80 - commutation capacitors is one name for their purpose - which speed up the switching between the stable states of TRleft on & TRright off and TRleft off & TRright on. If you want to learn how they work look at this piece:
Commutating Capacitor or Speed up Capacitor - EEEGUIDE.COM - https://www.eeeguide.com/commutating-capacitor-or-speed-up-capacitor/
Oh shi*/t - yes I didnt see it. It is referring to C6.
You see, the proteus simulator IS auto-renaming a lot. And is good for the most part. But not in my case with my static notes.....
I get a very nasty error -sometimes- in this simulator. Read carefully the timestep number. Is to the power os -17!!!! its enormous. So the simulator is doing some monkey bizniz behind the scenes.
My solution to add this cap there, on that node, was to delay that extreme small number.
It is a simulator thing. Not a real thing !
But I also get your point with :
"between the two halves of the bistable circuit otherwise it would settle happily on a 'knife edge' "
very good observation !
I made a movie about this project. I hope you like it.
I am not allowed to post my video link here on the forums, because marconi asked me to. The reason was 'swearing' and I can not change it at my age. Heh.
Instead, follow the link or search the name in Youtube and you should find it very Easy.
Mister @marconi
What is the role of the Set pin (4&10) on the 7474 chip? Besides setting or inverse of a reset.
Is it an input? If it is, then I believe it should be linked to + or -. To avoid random triggering. Right?
I believe I RE-solved the circuit problem and make it even smaller than it was and even better in functionality.
This is the new and improved cct !
All those INPUTS (S) representing the SET pin of the FF, are now linked to + rail, directly. This result comes from testing in reality. I was still having problems on the last (4th) FF on the CLK pin, with that bouncing button. But I believe, NOW when all these inputs are set to High, and not floating anymore, might affect the good functionality of the FFs. I think I am right... what you say?
Mister @marconi
Unused input and control pins should never be left floating to avoid spurious operation of the logic circuits.
Thank you.
Indeed. I remembered it way too late. I did mentioned that Im still learning the logic ICs, right? So the very big mistake I did was to Not convert properly the original cct into my ICs that I have ! But is a lesson for me. I spent 2 days on it. I think....
Thanks for those 2 pages. I actually have a VERY long history with bouncing buttons in my circuits, with various implementations (RC, 555) if you might even remember some of them, but I have these issues from long before you. And I come across, 'a time or two' (to paraphrase someone, haha) in my life over Denouncing ICs and I always overlook them. I think it is time to commit to take some of them IF they are cheap enough in bulk. I'll have to check it ! Very good reminder, looking over your 2 pages ! Thanks.
Yes, I give it a quick look over ebay and aliexpress and they are not cheap. Especially in bulk. Damn. When I say -in bulk- I refer to 100pcs, minimum.
Heh, 74HC00 used as a debouncing IC, that is very new to me ! Very interesting.
-I do know about RC debouncing cct, but to be very sincere, I did neglect it in my previous project. I forget about it. I was concentrated to the other important aspects of the larger cct. It is a good reminder though !
I have 2 interesting Questions for anyone here looking to my posts.
-Question1- What is the role of that 4011 NAND gate in the original cct ?
I have 3 Theories about its role.
  • T1: The role of the NAND gate is to automatic deactivate S1 to S8 AFTER LED1 is ON, by setting HIGH the first 3 Gates Reset pins, resetting them, until S9 or S10 is pressed, that in turn will reset only the 4th gate.
  • T2: If it is indeed a gate used to reset the first 3 FF's, why in the hell didn't do it like I did it? Linking all 4 Reset pins together. I am still absolutly perplexed why he used it there. It still has no sense to me. The only logical sense is if it was having some LEDs there, that he didnt wanted to keep them open when the last digit in the opening code was activated. For curious eyes, not to see which leds/buttons were activated. But it is not having any LEDs in the cct either. It is a true mystery that NAND gate there.
  • T3: The designer didnt know anything about logic ICs and he slap it there, just because, no reason whatsoever. Just to make a Bigger cct, for appearances that it is 'complicated' and fancy. He might be an idiot.
-Question2- Now the fun part! Hehehe. I already solved this problem. I worked on it probably 1 day and I figure out a solution. It is working fine in simulator, but I didn't test it on the breadboard. But I will very soon, just to be sure. If you like to play logic games, like I do, give it a try. I will post the cct I made, but after awhile. Not right now. I will give you time to think.
So... the cct we are using is from post #8 and the problem is like this:
- How would you add a LED for each Switch in the cct? To light when the button is pressed, but not all LEDs at once! Only when you press a certain button, its corresponding LED, let's say it's "parallel" LED, will lit up, telling you THAT button is in pressed state.
I will give you a hint. There are 2 sets of switches. 1 set are all linked between them and to the Reset pins, and 1 set are the ones for the Clocks. You will have to adapt to each set.
Again, I solved the problem and it is a very cool one. Haha. Happy designing !
Im very curious if you will come with the same or similar solution as mine, or completely different approach. Or nothing at all. Haha. Good luck. Let's see who will be the winner ! Haha.
I suggest you think first about what effect the series RC circuit of C1 and R7 has. So consider:
a. What is the waveform at U2B-Q* pin 12?;
b. What will the waveform be at the point where C1 and R7 join together in response to the waveform at a?;
c. How does U3A's output respond - the waveform which is sent to the Reset R inputs of the previous FFs - when it has as its input the waveform at b above?;
d. Now consider what would be the reset waveform with out using U3A, C1 and R7 which is the way you think it should be done.
e. Finally what effect do the two schemes have on the operation of the lock circuit including how the LEDs illuminate?
Here is the progress so far. Only 4/6 button modules are made so far. In the final cct I linked 6 Reset pins toghether and 4 buttons for clock pins. In total 10 btns. I tested what I have here and working just fine. But is hard work and slow. Slowly but surely.
All the components are scrapped and repurposed. Those leds are VERY old, 80's or 90's and quite dim to today standards. But bright enough for this application.
I managed to finish the Lock circuit. The final cardboard with everything on it. I also made a movie about it showing how it is functioning. WOW. Im very happy it worked from the first try ! I was very slow and careful when I build it. Also checked it many times while I was constructing it. Im very relieved I made it. Ohoha !
And, for completion, here is the end of the project.
I am not allowed to put videos here in this website; So if you google this:
q12 #208 Electronic Lock - Final Project Done
you will be able to see my final movie about it.
Also this one as well, why not:
q12 #207 Electronic Lock - The (card)board circuit finished
and also this one:
q12 #206 Electronic Lock - How I make an electronic (card)board circuit
Reply to Electronic Lock using 74LS74 DTFF in the UK Electrical Forum area at ElectriciansForums.net
Hello ! I am building for some time a cct to drive a 3digit multiplexed LCD. (from aliexpress) From the sellers on aliexpress I managed to find...
Background Two weeks ago, lightning struck a tree in our yard. Many circuits tripped and several electronic devices failed. There was a strong...
B
Prefix - I've tried to post this in automotive, but it would not let me. This may be because I have not been recently active. Apologies if this is...
