Discuss Emergency lighting in the UK Electrical Forum area at ElectriciansForums.net
Ok so i dont have a copy of bs 5266 so hopefully someone here has a good all round knowledge. Emergency lighting in a high risk fire industrial building (saw mill) do all emergency lights leading to an escape need to be maintained? A lot of ours on site are non maintained a mix of both (previous maintenance sparky installed them) and also at the outside of final exits maintained or non maintained? Im looking to upgrade everything to LED so would like to get everything up to scratch.
A non maintained luminaire should operate upon failure of the local general lighting for example if you have a non maintained luminaire in a corridor it should operate upon failure of the corridor general lighting, this is not important if they are maintained. Luminares at final exits I like to see internal Exit boxes maintained as it familiarises people who are not used to the premises where the exits are. External would be dependent on the general external lights, would a non maintained luminaire operate upon their failure.
I am talking dedicated emergency lighting for escape routes as in the lights that shouw you the direction to the nearest exit. We have maintained emergency lights within our general lighting that cover the entire inside of the building.
I would make them maintained personally as I said before it makes people unfamiliar with the building more aware of the exits.
Reply to Emergency lighting in the UK Electrical Forum area at ElectriciansForums.net
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
Hi all Got a question regarding HMO compliance. Visited property today for landlord looking to apply for an HMO license for one of their...
Two lighting circuits covering various communal areas on two floors of a HMO. The non-maintained emergency lighting that covers those areas is on...
Hello, I have emergency lights that require a ctu. They are a mixture of non maintained and maintained. Do I need a contactor and a ctu? If so...
