Search the forum,
Discuss EN standards of neon scredrivers in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hello people,
Not an electrician, but more of a quality controller. I've got to check for the compliance one those horrible neon screwdrivers for a company but I'm pretty stumped.
Some people say they should conform to EN 61010-031 and some say EN 61423-3. RAPEX has many of these listed with the most common problem as "protection rim on handle is too small". I assume that's the finger guards or lack thereof. Stanley had theirs withdrawn.
https://ec.europa.eu/consumers/cons...101/14&exclude_search_term=0&search_year=2014
The one I have is GS / VDE certified, but I have a feeling that it's just not enough and doesn't have the required finger guards. There market is full of them and some by reputable-ish brands like Draper.
Do the following standards actually cover this products or do they also require EN 61010-1 / 61423-3?
VIN VDE 0680 Teil 6/04.77
AfPS GS 2014:01
The standards quoted in your post are required by GS38, the guide produced by the HSE to ensure compliance with the EAWR when using test equipment on live parts. These screwdrivers also do not have the finger guards, 4mm or less exposed metal tips, or fuses required by GS38.
They are not suitable for use and should be exposed to the aforementioned hammer test before disposing of them in a manner in compliance with current recycling directives. :D
Electrical test equipment for use on low voltage electrical systems - http://www.hse.gov.uk/pubns/books/gs38.htm
I know they're crap, but the ones I'm looking at are for home / DIY use so I don't think HSE rules apply. All I need to know is EN standard that these should conform to.
Not entirely sure, possibly the ones you mentioned, possibly none at all. A call to BSi may be in order to determine the standard and to purchase the standard so you can adequately test for compliance.
I'm a BSI member and they're a bunch of idiots, all they ever do is search the store, they don't actually have knowledge of standards. The only reason to be a member is the discount on already overpriced standards.
That's even worse flogging them to DIYers, Jimmy
Reply to EN standards of neon scredrivers in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
