Discuss EPC listed building (church) in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
N
Noshocks
I am quoting on a ground mount array at the rear of a chapel, its 100's of years old, in a conservation area and listed as well, these are being addressed by my customer however obviously there is isent a cat in hells chance that this church with stained glass windows etc will get a D rating, however the clause on the FIT stating that it would never be possible to improve the efficiency, due to it being listed with windows etc etc that cant be changed, should mean that its exempt, yes?
Hopefully someone else may have come across a similar situation and can advise.
Isnt there meant to be change to the EPC requirements (I am not sure when these are going to take affect mind) meaning community organisations and small business (less than 50 employess) don't have to have an EPC of D or above? but strangely they will still need to have an EPC as part of the application but not in order to get the higher FIT rate.
http://www.decc.gov.uk/assets/decc/...t-response-to-consultation-on-comprehensi.pdf
A number of consultation respondents put forward evidence about the difficulty of delivering energy efficiency improvements for community buildings. We have therefore decided to exempt all community energy solar PV projects on non-domestic buildings from the requirement to reach EPC level D. We believe that the uncertainty about achieving a level D EPC is preventing some community energy projects from going ahead that would have done so otherwise. However, it is important that FITs is seen as part of a total package of improving the carbon performance of these buildings, so we will require that prospective generators must at least obtain an EPC (with no specific level required) dated on or before the eligibility date so they are aware of the potential improvements they may wish to pursue.
Surely this has to include a church? if a church is not community project then I don't know what is
Yes, but wouldn't the church authorities have to jump thru a whole load of hoops to become properly registered? Considering the fact that many (especially rural) churches share clergy between several parishes, resources are clearly stretched and extra paperwork is hardly what they need.
Yep but the Diocese head office will have lots of resources, and they talk to each other, so quite a few will already be discussing this internally. - What denomination? CofE presumably if so , just ring the Diocese office and speak to their financial controller, - they will want to help. Who knows you might end up doing a dozen churches.
Im surprised you have the go ahead for this ground mount considering where it is
I was coming on to ask the exact same thing. We are quoting for a church at the moment and I am not sure whether or not they require an epc.
They have just had an ASHP intalled and insulation to the church hall along with a few other measures but I am not 100% sure on the epc situation.
Who is the best person to get this clarified.
Resurrecting an old thread, has anyone seen any update or draft legislation on this recently?
When the announcements were made they talked of "community energy solar PV projects on non-domestic buildings" being exempt the requirement for an EPC level D, but never made it clear whether a church might fall within the category. As I have just put in a quote for PV on a listed church I am interested.
Reply to EPC listed building (church) in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
What are your thoughts on using electric underfloor heating as a primary heat source in a church? It's a typical old church building - a couple...
Y
Effective yesterday (9/1/13) DCLG (Dept for Communities and Local Government), officially exempted a range of buildings from needing an EPC: Not...
4K
yorkshiremike
Y
Thought this may be of interest to everyone before 1st August Special Scheme Operating Requirements Top Tips We received revised Scheme...
babba
B
