Discuss Exporting the earth? in the Electricians' Talk area at ElectriciansForums.net
R
Robo
Im not 100% on earthing for submains. If the supply is tnc-s you are not ment to export the earthfrom db to say a detached garage?If i did export the earth could it not be classed as TNS instead?? Or to keep it TNCS run a seperate earth form cutout.Or just have the garage as a TT.
Are you aloud to export TNS from 1 db to another?
Or i could rod the garage and then it would be seperate?
Under the Electricity safety, quality and continuity regulations 2002 you cannot use a suppliers earth to an out building, on a TNC-S Earthing arrangement, so the detached garage effectively becomes a TT installation with an earth electrode installed in the ground.
If you use SWA to supply the garage the armour must not be terminated at the garage end of the cable.
Bit unsure re your TNCS to TNS
If you create a new earth at the garage that would have to be via a rod so it would be TT.
If you were to continue with a earth from the TNCS system it would remain that system and not change to TNS. Some DNO companys don't like you exporting it.
How far away is the detached garage and don't forget to bond in the garage.
I dont actually have a job, im just enquiring for the future. Would it be ok to gland garage end and just not connect into earth bar, providing its insulated. If it was metal then use a stuffing gland and dont bother with armours.
That is absolutely incorrect, please read the Guide that I posted and Guidance Note 8.
This is the link to the thread: http://www.electriciansforums.net/e...159-good-guide-exported-pme-outbuildings.html
If you are useing the earth from the TNC-S to protect the swa cable and then isolating it from the garage which now becomes TT.
I would use a insulated box so that both earths are kept seperate so you are only transporting the line conductors.
Seems the myths and mis-information on this topic continues... To my mind, Rods (TT) should always be considered as your last choice, not a first choice!!!
New posts
Reply to Exporting the earth? in the Electricians' Talk area at ElectriciansForums.net
Hi All, I have a question trying to understand earthing arrangments SO, We have a DNO Substation, 4 Core armoured Feeding the Distribution Board...
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
Hi all, Merry Christmas to everyone, and apologies for talking work during the holidays😅 I have my first EV charger install job early in the New...
5 single phases to one huge property. Backup generator which can take about 106 amps split between 2 phases - 1 phase will be wired through...
