Discuss Extra emergency lighting fittings on minor works in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Shweblet
Trainee
Hi guys,
Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding multiple other fittings and emergency lighting (all of the lights were selected and at the depot when I got there) they were supplied by the lighting company next door. Em lighting was existing but adding extra fittings.
Obviously a minor works cert. Would suffice for the addition of the light fittings, but no certificate of conformity has been mentioned which I'm sure they're going to need.
Can I just issue the minor works certificate for each circuit, 1x lighting, 1x emergency light fittings and be done with it or do I need to go through with getting the emergency lighting cert sorted?
I'm registered with Napit but they haven't really given me much direction with it.
Reply to Extra emergency lighting fittings on minor works in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
I've been asked by a client to 'mask off' the green LED charging indictor lamps within several emergency lights fitted within bedrooms on a...
Hi all. Removed an ancient light fitting, replaced with a newer one, the light comes on but can't be turned off with the switch. It was working...
