Search the forum,
Discuss Extractor fan not working in the UK Electrical Forum area at ElectriciansForums.net
Hi > I need advice regarding an extractor fan that is in the kitchen hood which has stopped working . I have been told it is old and the whole thing needs to be replaced . Is this the only option I have ?
anything can be repaired, it is just figuring out if the parts and labour are less than replacing it with a new one.
With older commercial kitchen extract fans you should be able to replace just the motor, bladeset or diaphragm plate. That said there's often severe corrosion and grease and even fatigue cracks on the motor pad mounts or the casing which makes it financially more viable to just replace the entire fan unit.
Also downtime is often a big consideration where the kitchen may be closed for a day or two whilst an old unit is rebuilt compared with a few hours downtime for a new replacement fan.
Reply to Extractor fan not working in the UK Electrical Forum area at ElectriciansForums.net
Hello, I'm swapping my extractor fan in the UK and I have bought a Turkish extractor fan stupidly and the connections you can see in the picture...
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
Hi Customer has an extractor fan that’s inside the shower cubicle high up on the wall. The extractor fan has no form of isolation and is wired...
Hi, my niece lives in a flat and has a bathroom without a window. There is an extractor fan which packed up and an electrician installed a new one...
1964 house old style wiring Need to wire a extractor fan up Is it possible to wire the extractor fan to report switch there's 2 red wires in the...
