U
UK.will
Hi. I have an extractor fan in the bathroom which is switched on/ off by a humidity sensor. The humidity sensor is wired into the lighting loop for the upstairs at my house. Whenever a light is turned on (where the light is connected to the same loop as the humidity sensor) this also trips the sensor and turns on the extractor fan. I figure the humidity sensor is very sensitive?
I guess if I wire the humidity sensor into a different lighting loop, say the loop for the downstairs lights, then the extractor fan will trip on whenever a light on the downstairs loop is switched on or off. I will have the same problem I have currently.
I could wire the humidity sensor into the fuse box on its own fuse but this seems like a lot of work.
my other idea was to buy some sort of filter/ damper to wire between the lighting loop and the humidity sensor to soften out any spikes caused by the lights on that loop being switched on/off.
Any ideas if a damper/ filter exists and where I could find such a thing? Would this work or is there any easier way to stop the humidity sensor tripping?
