Have noticed the fans that don't need the 3A fuse are at the top end of the price range,like the ventaxia inline fan and the Greenwood 100m wall fan(£80).
But can make the install easier.
Regards,S
Regards,S
I don't actually know but that is the purpose of the 3A fuse. I found a university study into this a while ago, can't find it now which found it to be highly unpredictable dependent on fan and/or fuse manufacturer.
I think most of the motors in domestic fans nowadays are covered as 'impedance protected' (ZP) as per UL 1004-2 requirements where they're less than 100 watts and their internal impedance is sufficient to prevent their temperature increasing above a certain point under a prolonged locked rotor condition. If so it's unlikely they'll have a thermal fuse on the windings.
A 3Amp fuse on the supply would only blow if there was complete winding insulation breakdown and a flash fault. I guess the thinking is that the internal wiring might be too small CSA to achieve a high enough fault current to achieve disconnection by the OCPD on the final circuit in the consumer unit.
